Need Help
Hi I just upgraded the system from
AMD Phenom(tm) II X4 955 Processor
ASUS Computer INC. M4N68T-M-LE-V2
Corsair 6GB DDR3 1333MHZ
Bijli 2 Atx cabinet
NVIDIA GeForce GTX 560 Ti
SyncMaster 2233SW
Samsung DVD writer
WD 320GB 7200RPM
Corsair 650W
to
i7 3770K
Corsair Vengeance 8 GB (2*4) DDR3 1600 MHz
Gigabyte GA B75m d3h motherboard
Bijli 2 Atx cabinet
NVIDIA Ge Force GTX 560 Ti
Sync Master 2233SW
Asus DVD writer
Corsair 650W
M questions are :
Is it a good configuration to play games like BF3, COD, Borderlands etc? (I just purchased 560ti don't want to replace or sell it)
The motherboard is an entry level motherboard do I need to change it (I am not a overclocker)?
Which Hard drive should I go for (100 to 200$)?
Is it a good upgrade on AMD?
2 answers Last reply
More about need help
  1. i7 3770K
    lol it is wrong match...
    b75 mobo is for low intel cpu like pentiums....
    get z77 mobo :)
    btw, you have bought them anyway
    it will work :) dont need any change
  2. ASRock Z77 Extreme4 for the motherboard. Get a SSD, intel 330 series 180GB is good value for money.
Homebuilt Corsair Systems
