Solved
Building a Gaming rig: Are these parts compatible?
Hi everyone. I am building my first gaming rig. I just wanted to know if all of these parts are compatible before I put it together so I can see which ones I have to return. If there are incompatible parts, please suggest a replacement that is compatible, for it would be extremely appreciated.
CPU: Intel Core i5-3550 Quad-Core Processor 3.3 GHz 6 MB Cache LGA 1155 - BX80637I53550
Motherboard: MSI Computer Corp. DDR3 1600 Intel LGA 1155 Motherboards (Z77A-G43)
Graphics Card: EVGA GeForce GTX 660 SUPERCLOCKED 2048MB GDDR5 DVI HDMI DP Graphics Card 02G-P4-2662-KR
RAM: Corsair Vengeance 8 GB ( 2 x 4 GB ) DDR3 1600 MHz (PC3 12800) 240-Pin DDR3 Memory Kit for Core i3, i5, i7 and Platforms SDRAM CMZ8GX3M2A1600C9
Hard Drive: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA III, 64 MB Cache - WD10EZEX
PSU: Here is where I have to decide between
Corsair CX750 Builder Series ATX 80 PLUS Bronze Certified Power Supply
or
Corsair Enthusiast Series TX 750 Watt ATX/EPS 80 PLUS Bronze (TX750)
Thanks to anyone who answers in advance!
9 answers Last reply Best Answer
More about building gaming parts compatible
  1. Looks fine, since you are not overclocking a 550W Psu such as this one will be enough.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013
  2. Best answer
    I see no issues get this power supply http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013#top and here the best building pc tutorial - http://www.youtube.com/watch?v=ea_bs5G1yYU
  3. that is the exact same psu
  4. So my graphics card and my cpu won't bottleneck, right?
    No chance. Pretty sure that CPU wont bottleneck any GPU.
  6. No your fine no bottleneck
  7. Ok great. Thanks so much everyone for their answers and suggestions! I guess this is the place I will come to when I need help.
  8. Best answer selected by Hlau95.
  9. No problem.Your welcome.
Homebuilt Compatibility Systems Product
