Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > cleaning the LCD monitor
Forum Computer Peripherals : Flat Panels/ LCDs - cleaning the LCD monitor
I used glass cleaner and paper towel and did it softly, is it ok?
Sponsored Links
Terrible!Just use some special equipment for LCD,your action will damage the protection coat of the LCD.
Reply to neveroldmilk
It's probably fine. But as a general rule, you should never use glass cleaner on your monitor, especially LCD's. Either use a mild soap or just a damp cloth.
Reply to kinetic_tw
There are 903 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
