Corsair 300R case
Intel DZ77SL-50K motherboard.
motherboard is lined up with the stand offs built into the case, with the center bolt through the center ATX mobo alignment and the back slots alligned with the back plate.
If you imagine an ATX mobo having a 3x3 grid of standoff points, the upper middle stand off screw WILL NOT screw in. Around and around it goes, to no avail. I've tried with 2 other screws as well, so it's not the screw; i fear it's the standoff screw hole. The other 7 standoff screws fit well, the middle standoff seems to be alright, although there is no obvious bolt to place on it.
Question: Can I get away with 8/9 mounts on the motherboard? Any other suggestions about the screw hole that won't take?
Thank you.
Thank you.
