Hello,
I've built a new system with the following components
Intel i3 2120
MSI H61 Motherboard
Cooler Master PSU
4GB RAM
I've plugged everything in (I think) but when I press the power or reset button, absolutely nothing at all happens. All the components are new. I've been through the checklist in this forum to no avail.
I've tried:
-switching the polarities of the power switch cable
-a different mains power cable
-the switch on the back of the PSU is on
-the motherboard power connector is plugged in (there are two 4 pin connectors which both fit, ones labeled P2 but neither works)
-I installed the motherboard standoffs from the start
-I have integrated graphics so video card is not a problem
Even the PSU fan doesn't come on.
I did bend one of the pins in the CPU socket when installing the CPU but it's not touching any other pins and the CPU is in the right way round. Surely the PSU fan should still come on even though there's one bent pin?
Thanks for reading, I'm completely out of ideas.
Intel i3 2120
MSI H61 Motherboard
Cooler Master PSU
4GB RAM
I've tried:
