Power Supply?
Forum CPU & Components : Other Components - Power Supply?
I bought an Antec midtower w/t its 300watt power supply for $59. I will be running an Athlon XP 1600-1800 and a Visiontek 5864 250mhz AGP card. Is that power supply enough or should I return the case and get a different case/power supply?
Thanks,
Robert
Sponsored Links
What other components do you have?
Reply to upec
- 0 +
If it's a "typical" system with those components, I think it would be minimally enough. But again, as posted above, it depends on the other components of your system - and I wouldn't recommend a 300w power supply for a system of this type anyway.
Rob
Please visit <b><A HREF="http://www.ncix.com/canada/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/canada/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
Here is what I have sitting in boxes:
Sound: Philips Acousticedge 5.1 $39
Video Visiontek Xtasy 5864 64mbDDR 250mhz $89
Modem: U.S. Robotics PCI $29
CDRW: TDK 241040 $129
Ram: Crucial 256DDR PC2100
Monitor: KDS Rad5 LCD $309
Floppy $9
USB: 4 port Belkin powered hub $9
Logitech Cordless keyboard & Mouse $30
Reply to Anonymous
- 0 +
300 Watt should be enough.
Reply to upec
When would I need a bigger power supply?
Reply to Anonymous
- 0 +
There are a number a symptoms - most commonly being system freezes and reboots on its own.
Rob
Reply to Arrow
Tom's Hardware > Forum > CPU & Components > Other Components > Power Supply?
There are 784 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
