Will my new future build work together
Last response: in Systems
Hello guys,new to the forums and have a question for you.I would like you to tell me with my new pc i am about to build work together.
case: CM692 standard black.
PSU: OCZ modxstream pro 600W
mob: Asrock 970x extreme3
CPU:p henom II x4 965BE
GPU:ATI HD 7870 2GB(probably)
RAM:G.skill ripjaw x series 8gb/maybe 16gb 1600Mhz
HDD:my old one
SSD: some 60gb one for windows
Cooler: CM 212 evo
around 5-6 fans
I know how to connect it all and stuff but i just have few questions just to be shure.
1.Is the PCU strong for this or i need stronger like 650W or smthing. (I plan to OC the CPU)
2.About the RAM,how will it all work since this cpu doesnt support 1600mhz,will my motherboard automaticly underclock it to 1333 or do i have to do it?Will i see the diffrence in it?Does the ram work with the board then?
More about : future build work
Related ressources
Thats the problem i cant remove it because i got it for free,and if i sell it i wont be able to get a better one.
My budget is around 620$ but i am from croatia and everything is aloat more expensive here.For the GPU i will have to sell my curent pc and add a little bit to be able to buy it.
Homebuilt system Expert
Would Suggest you a CX500 atleast or a CX600
I'm less familiar to OCZ PSU.
If those work fine then you'll be good to go.
Even 500w is enough for OC too.
Your Computer will not much Power
I've heard that CPU Overclock near 4Ghz and Equals a i3.
Which would result in a Good Performance and No Bottleneck.
But not sure if its true.
You can lower and get a Radeon 7850
Ok thanks man aloat!!! Will see in the end how will i stand with my money :)  Also for future build i can always pop in a Fx 8350 and a 990fx motherboard.(If i sell the ones i have,But latter)
Ok but now i would like if someone could answer the second question plsss that would help me aloat :D !
