With the Extreme4 there is an LED troublehooting display at the bottom of the board that will display a number that wil tell you what is wrong with the system.
Are you refering to the motherboard splash screen? It should feature the engine-looking thing thats on the box. If you seeing that you'v gotten to POST.
Do you know how to build a computer? I can link to a few good tutorials if your unsure on how.
NCIX Gaming Build guide. http://www.youtube.com/watch?v=84NvDMMrCNU
Note that it is nothing like a typical gaming build, all the parts involved are overkill for demonstration purposes.
