Just ordered my parts - will it all work?
CASE Zalaman z11 plus
MOBO ASUS p8z77 v lx
CPU I5 3570k
GPU Sapphire 11200-14-20G OC 2GB, HD7850, GDDR5
CPU HEATSINK Arctic Cooling Freezer 13 CPU Cooler
PSU Corsair CX750
RAM Corsair CML8GX3M2A1600C9B LP Vengeance Memory 8GB 1600MHz CL9 DDR3
What do you guys think? Cost a pretty penny.
5 answers Last reply
More about just ordered parts work
  1. yes all gonna fit ;) did you get an SSD?and you styill have some headroom for crossfire 2nd gpu ;))
  2. No SSD, budget streatched too faras is. My memory doesn't seem to be listed as supported, do you think that could be a problem.
  3. no its 1600 MHz and your mobo supports it dont worry
  4. Should work out just fine. The PSU is a bit overkill, but then again it leaves you a good bit of room to grow. You better be overclocking that thing.
    Supported memory just means they stuck those models of RAM in that model mother board and said "oh look it works". I've never worried about that. The only time you really need to be careful is with OEM systems (Dell, HP, etc). Sometimes they can be funny.
New Build Systems
