G
Guest
Guest
Hello, I'm looking for build recommendations for a new computer. My ultimate goal is to take full advantage of a 27" monitor that I'm planning to buy. More specifically using it more importantly for watching movies first, then casual gaming, and then more common things like surfing the web and all. All at 2560 x 1440 if possible.
Also, I was thinking on this build, and wanted to know if it's okay? Your recommendations to change it? Or would a totally different build would be better?
This is the build I'm planning on buying:
CPU: AMD FX AMD FX-8150 28.8Ghz (3.6Ghz x 8)
Mother board: Gigabyte GA-990FXA-UD3
RAM Memory: Corsair DDR3 8GB X1 1600Mhz Vengeance
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Sapphire ATI Radeon HD 7750 1GB DDR5
Case: NZXT Lexa S Crafted Black Neon Blue
Power Supply: CoolerMaster ExtremE EX2 Power Plus 525W
The monitor I'll buy is: Dell UltraSharp U2713HM 27"
Thank you!
Thank you!
