Solved
UPgrade my system please help!
Hi guys
Approximate Purchase Date: 2 Years back
Budget Range: 300
System Usage from Most to Least Important: gaming, surfing the internet, watching movies
Are you buying a monitor: NO.
Parts to Upgrade: Graphics Card and CPU
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com.
Parts Preferences: by brand or type : would like to keep my Mobo so only amd 2 CPU
Overclocking: NO
SLI or Crossfire: NO
Your Monitor Resolution: 1280x1024
And Most Importantly, Why Are You Upgrading: Having a little freeze lag trouble sometime with my games, and intending to play wow and GW2, i know my computer cannot support now so i wish someone could enlighten me.
My current PC Specs.
Proccesser: AMD Athlon 64 X2 4000+ Brisbane 2.1GHz Socket AM2 65W Dual-Core Processor ADO4000DDBOX
PSU: acbel atx12v power 510 450W
Ram: 2GB
Graphics: MSI NX8600GTS 256MB 128-bit GDDR3 PCI Express x16
Fan: addition 2 fans
MB: MSI K9AGM3 motherboard, socket AM2 for AMD CPU and AMD 690G chipset.
Will be looking at upgrade of graphic and CPU(If needed) can anyone experiences forumer show me some lights :)
18 answers Last reply Best Answer
More about upgrade system help
  1. Something like this, then
    CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($89.99 @ NCIX US)
    Motherboard: ASRock 970 Extreme3 ATX AM3+ Motherboard ($74.99 @ Newegg)
    Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($35.57 @ NCIX US)
    Video Card: XFX Radeon HD 7770 1GB Video Card ($109.99 @ Newegg)
    Total: $310.54
    (Generated by PCPartPicker 2013-01-08 07:19 EST-0500)
    Total: $310.54
    whoa thank you very much. But just a question will my PSU be able to handle this available upgrade or i have to change them?
  3. A wattage of 450W should be enough since the HD7770 sips power - however the quality of your PSU is suspect. If I were you I'd replace it.
    as in the freeze lag should be cause by PSU? if so what would you recommend for a decent and cheap PSU for the long run.
  5. Antec, Corsair, Seasonic or XFX about 500W unit.
    ok noted thank you very much for the help it helps me solve what i need to do :D
  7. Best answer
    You could drop the ATX and get a mATX for less, then get the trusted PSU.
    Motherboard: Gigabyte GA-78LMT-S2P Micro ATX AM3+ Motherboard ($49.98 @ SuperBiiz)
    Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($29.99 @ Newegg)
    Total: $315.52
    (Generated by PCPartPicker 2013-01-09 11:58 EST-0500)
  8. He's not in the US.
    Total: $315.52
    Oh does the one he quote with shipping fee?
  10. Not abroad, no.
  11. FinneousPJ said:
    Not abroad, no.
    ic. yours was right?
  12. No, unfortunately not.
  13. Best answer selected by ValsonLGW.
    can i check if i have a friend in US. Could i just purchase whatever you all mention and send to his house and follow by asking him to mail it through UPS for me?
  15. Perhaps. I recommend buying locally though for simplicity.
    alright thanks
Homebuilt Systems Product
