Where do I plug in power switch cable
I can't not for the life of me find the place to put the power switch cable. I have the Asrock Extreme 4
3 answers Last reply
More about where plug power switch cable
  1. Look in your manual (pg. 38) for the system panel connector layout. I assume you are talking about the power button 2 wire connection from the front panel of the case.
    It plugs into the same area as the reset switch, HDD and Power LEDs, etc.
    If not, please clarify.
  2. the little flat piece that the wires run into that connect to the motherboard.......... look at the back carefully. there is an arrow on the back below one of the wires. that one will be your +positive+ lead........ same with the rest of the wires.
Homebuilt Power Switch Cable ASrock Systems
