Yes No
Ads
Tom's Hardware > Forum > Networking > General Discussion > Help networking quickbooks
Forum Networking : General Discussion Help networking quickbooks
Hello, I am wanting to network my new lap top with my desktop so I can work on my quickbooks from both computers, any suggestions? I'm clueless!
Reply to Nadine Harskamp
On the desktop where you should be HOSTING the file you'll need to share the "Company Files" folder. Once that's done, go to your laptop and create a network drive pointing to that particular folder. After that you can go into QB and tell it where to pull the file from.
Depending on your license from QB determines if you can use the file at the same time on both machines.
The "Company Files" folder will be under the "Public" (Win7) Users folder or the "All Users" (XP) folder, then documents>intuit>quickbooks>company files.
For the record though, Quickbooks doesn't recommend running the program over a network. But I havent had any issues really with that part so you should be ok.
------------------------------ For all your computer needs.
www.advancedtechinc.com
Reply to josh-advancedtech
Sorry, also make sure obviously that you're on the same workgroup/domain and same subnetted, IP address network.
Also, you're going to find out how slow Quickbooks is over a network. Logons are painfully slow.
Reply to JFerrera
You can try hosted QuickBooks. QuickBooks hosting on cloud offers very fast and remote accessibility from any computer on this planet via Internet, simultaneous accessibility for multiple users, utmost security, high reliability, extreme scalability, rolling data backup, economical pricing, and 24 by 7 unlimited technical support and customer care services.
Reply to William Smith
There are 1578 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
