Tom's Hardware > Forum > CPU & Components > Sound Cards > will this card work with xp?
Forum CPU & Components : Sound Cards - will this card work with xp?
i got a tsunami dj-4100 and its drivers are compatible with dos,95,98,ME,2000,NT4.0 and linux but it doesnt say ithas xp compatibility and i cant seem to find any driver updates
Sponsored Links
You might be able to use the 2000 drivers with XP in compatability mode.
What's the frequency, Kenneth?
Reply to Crashman
It is my opinion that XP is very picky with soundcards. I tried to install a nonXP ready board and never heard a peep out of it. You can try using the 2000 drivers, but it still may not work and may corrupt your OS.
If it works for you then don't fix it.
Reply to arsend
Non XP-ready sound card? What sound card was it?
<font color=orange>Quarter</font color=orange> <font color=blue>Pounder</font color=blue> <font color=orange>Inside</font color=orange>
Reply to FatBurger
There are 478 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
