Solved
Will these parts work together?
goo.gl/F3qGm - CPU fan $20
goo.gl/hh5ky - DVD drive $30
goo.gl/YMc0k - memory $35
goo.gl/P2qsl - case $100
goo.gl/IhCyJ - power supply $61
goo.gl/2yyJd - motherboard $65
goo.gl/CUOSP - mouse $81
goo.gl/q6Egc - operating system $100
goo.gl/haq9T - processor $220
goo.gl/BXmk5 - graphics card $385
goo.gl/lE0KG - keyboard $55
goo.gl/yjQff - monitor $130
What I am mainly concerned about is my motherboard choice and its compatibility with my graphics card and if I would be able to overclock my processor and graphics card with that motherboard, also I am not sure if the power supply is enough. (operating system, mouse, keyboard, and monitor should work fine though, right?) Also how do I know if my motherboard had wifi?
13 answers Last reply Best Answer
More about will parts work together
  1. All of your links are dead.
  2. no not of all of these parts will work together,
    you have an amd based motherboard and amd heatsink fan for an intel cpu.
    you need to either get an amd processor, or get an intel motherboard and hsf.
    also you have an ide dvd rom drive, for a motherboard that does not have an ide port. i suggest you get a sata dvd rom drive the price difference is not great and it would be hard to find a motherboard with ide
  3. the 2 easiest changes to make your set up work would
    this amd processor
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16819113284
    and this dvd sata drive
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16827106289
    while i would prefer to go intel this is what i would do. also i assume you are from canada so i pulled these from canadian newegg. tiger direct should have these as well or similar.
    also i did not see a harddrive on your list you need a hard drive i hope it is sata.
  4. Your powersupply is enough you can go more if you feel like it and it would leave room for adding more videocards etc in the future if you wish. as for overclocking yes but i do not know how far you can push since i have no experience with piledriver
    this amd processor
    http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1083959&Sku=TSD-500ST I thought I posted the hhd sorry but it is sata
    the reason I am going with tiger direct at whenever I can is because I wish to pick it up locally and avoid shipping fees but I would like new suggestions for a board, and heat sink, I would prefer intel. and if you do suggest a new mother board what dvd drive would be compatible with it?
  6. Best answer
    Your motherboard and heat sink man are for AMD processors. Get an intel 1155 socket z77 motherboard such as this: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3431743&CatId=6975
    You need the z77 chipset if you want to overclock.
    Get this heat sink fan: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=1284316 It is a forum favorite and will work very well.
    Any SATA dvd drive will work with any modern motherboard. Get this one: http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4814646&Sku=S203-8592%20OEM
    thanks that solves allot of my problems and as in "you need the z77 chipset if you want to overclock" do I have to buy a chip set separately? Or are you using chip set as a term for motherboard (I'm new) and if so would the board in the link that you sent me allow me to overclock my cpu and gpu?
  8. As long as it is a "z77" board you will be able to overclock. I have the board I posted to you and I like it a lot. It will allow you to overclock your CPU as long as it is a "k" edition CPU.
    You can overclock your GPU on any MOBO. You use a third party program to do it.
    thank you!
  10. Best answer selected by mradrianaslani.
  11. Always glad to help!
New Build Graphics Cards Motherboards Systems
