Hi, I've just replaced a few parts of my PC and put it all in a new case. Everything is working fine apart from the power switch. The only way you can turn it on is from the motherboard switch. I have seemingly connected it up all fine. My Motherboard is an MS-7578 and I am using the block of connecters labeled JFP1. My case is this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-ZA&groupid=2362&catid=2277&subcat=
I'm quite certain that I have the polarities correct for I am following the manual. The case is brand new so I doubt it's a problem with the case.
What does anyone suggest?
