Help - new to picking parts :D
1117248
54
Hi there community, I am buying some new computer parts. I have limited experience but prefer to buy something that will last over time by spend a little more $. I have picked out some parts listed below and was wondering if I could get advice on three things.
1. will these parts all work together, fit on motherboard, fit in case, have enough power etc, is it sufficient cooling...
2. did i pick any bad parts/bad company manufacturer or parts that can be beaten by a competitor in performance for roughly similar price or less?
3. is any parts i missed?
System Usage from Most to Least Important:
i play lot of computer game at semi professional level and i like to stream them through twitch tv without any performance drop
Preferred Website(s) for Parts:
i am in australia and have used http://www.pccasegear.com so far
but have used www.mwave.com.au in the past
Country:
australia
Parts List so Far:
x1 Corsair Obsidian 800D Case
http://www.pccasegear.com/index.php?main_page=product_info&products_id=12727
x1 Eaton 5110 Line Interactive UPS 1500VA
http://www.pccasegear.com/index.php?main_page=product_info&products_id=21604
x2 ASUS VE248H 24in Widescreen LED Monitor
http://www.pccasegear.com/index.php?main_page=product_info&products_id=16558
x1 CoolerMaster Silent Pro Platinum 1000W
http://www.pccasegear.com/index.php?main_page=product_info&products_id=21295
x2 Corsair Dominator CMP32GX3M4X1600C10 32GB (4x8GB) DDR3
http://www.pccasegear.com/index.php?main_page=product_info&products_id=19079
Samsung 830 Series 512GB SSD Retail Box
http://www.pccasegear.com/index.php?main_page=product_info&products_id=20926
Intel DX79SR Motherboard Retail Box
http://www.pccasegear.com/index.php?main_page=product_info&products_id=20942
EVGA GeForce GTX 690 4GB
http://www.pccasegear.com/index.php?main_page=product_info&products_id=22189
Intel RTS2011LC Liquid Cooling System
http://www.pccasegear.com/index.php?main_page=product_info&products_id=18914
Intel Core i7 3970X
http://www.pccasegear.com/index.php?main_page=product_info&products_id=22098
Western Digital WD Green 3TB WD30EZRX
http://www.pccasegear.com/index.php?main_page=product_info&products_id=17275
Overclocking:
i dont know what this is
SLI or Crossfire:
i dont think i need this is i just get that 1 graphics card
Additional Comments:
i really appreciate this communities help on this as i received many assistance last time i used this site. thank so much.
cheers,
1117248
Case: Expensive but good.
UPS: Not necessary, but not a bad idea.
PSU: Go with a Corsair TX 750W
RAM: 16GB would be more than enough. 2x8GB DDR3 1600MHz
SSD: Good
MOBO: Why not go with Z77 and get a 3770k?
CPU: Switch to 3770k to save a lot of money
GPU: Best you can get, but either get 3x1080p monitors or a 2560x1600. It will be a waste to game on one 1080P monitor.
HDD: Slow but a lot of space
Cooling: With the money saved from switching to Z77 why not do a custom water loop?
SSD: Good
54
Thank for your quick response!
i got this because I spend such money on the parts
could u elaborate exactly what u mean by this cause im a novice
the reason i pick the biggest one is cause streaming uses alot of cpu im told
thats what i was go for, mainly to store movies
i had problems with my cpu overheating in past, i dont really know what a custom water loop is, will that intel one keep it icy colds :D?
thanks for your time
1117248
p.s. whats the difference between 1600mhz and 2133mhz ram? why u suggest the 1600?
1117248
54
by this i mean what the difference between the two models i,e, the one i pick and ur suggestion?
The reason I said 3770k over the 3970x is the difference of ~$650. Also, the z77 mobo will be cheaper. You could take this extra money and put it towards a better monitor. I just got a 2560x1440 monitor and highly recommend it. You will notice no difference in gaming between the 3770k and 3970x. If you don't feel comfortable build a water loop then just get a good air cooler like a noctua.
1117248
54
things have gone bad in the past when i tried to change the ram, install an ssd and change the cpu fan... wow it ended bad... i broke clips, destroyed the ram-cause i was following an online tutorial that was running on the PC that i was changing the ram in... :-/ bent pins... Heh =.=''
