Solved
New Build are these parts compatible ?
Approximate Purchase Date: Somewhere between now and 2 months.
Budget Range: About 400$ no rebate no shipping needed.
System Usage from Most to Least Important: Gaming, surfing the Internet, watching moviees, Folding@Home.
Are you buying a monitor: No
Parts to Upgrade: May Re-use *Antec VP-550P 550W Strictly PSU* but the new case I've chosen comes with another 1 too.
Do you need to buy OS: No
Preferred Website(s) for Parts: http://www.umart.com.au/newindex2.phtml?bid=2
Parts Preferences: no real preference
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: 1920x1200
Additional Comments: Just wanting to know if these parts are compatible with each other. I've done as much research as I can to find out if they are and I just want a bit of reassurance about my choices.
And Most Importantly, Why Are You Upgrading: I'm rebuilding because my old computer is getting real old (6 or more year I think) and over the last few years I've had to change a lot of parts with replacements.
Now I can't seem to play most games because it will freeze and require a computer reset or it will crash to blue screen.
I have been trying to figure out why this is for awhile with little or no success.
so I figured time to get a new pc and I will miss the old girl so much, she had been so reliable and good to me for so long but alas all good things must come to an end. :(
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
CPU: Intel BX80637I33220 CORE i3 3220/3.30GHz/3MB CACHE/LGA1155 - Internet Price: $122.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=13&bid=2&sid=97779
Motherboard: ASRock H77M.H77 2xDDR3 2*PCIex16 GBL RAID DVI HDMI VGA USB3.0 SATA3 uATX - Internet Price: $79.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=177&bid=2&sid=92150
Memory: Corsair 4GB (2x 2Gb) CMV4GX3M2A1333C9 (1333MHz) DDR3 Performance solution RAM, non-ECC, 2x240-pin DI - Internet Price: $26.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=153&bid=2&sid=100285
Storage: Western Digital 500G SATA3 HDD Caviar Blue - Internet Price: $59.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=129&bid=2&sid=70536
DVDRW Drive: LG H24NS70/90/95 SATA 24X+- Super Multi DVDR Black - Internet Price: $20.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=20&bid=2&sid=104360
Case: Thermaltake V3 Black Edition Mid Tower Case With 500W PSU - Internet Price: $69.00
http://www.umart.com.au/pro/products_listnew.phtml?id=10&id2=216&bid=2&sid=82542
Video Card: Gigabyte GTX550TI DDR5 1GB HDMI/DVI - already owned got only a few months ago.
OS: Microsoft Windows 7 Home Premium 64bit OEM - already owed got only a few months ago box not opened or used.
Power Supply: Antec VP-550P 550W Strictly PSU - already owned got only a few months ago / also the case comes with a PSU but doesn't say what kind.
Monitor: Dell ultrasharp 2407wfp 24 flat panel lcd monitor - already owned hand it for 6 + years still works great.
Total price: 375$
I don't know if I've forgotten anything.
I'm sure someone will point it out if i have.
8 answers Last reply Best Answer
More about build parts compatible
  1. Best answer
    Hi. Yes those parts are compatible and I'm sure you're aware of the fact that the motherboard has only 2 memory slots.
  2. I was not aware but I only need the 2 don't I ?
  3. Oh I forgot to say Hi as well.
    So hi.
  4. Yes I meant if you decide you want to add more in the future.
  5. There's nothing wrong with 4GB. I was just making sure of your choice to go with 4GB instead of 8GB.
  6. Ah I see but I think I will be fine with just the 2.
    Thank you for your help.
  7. You're welcome and good luck with your build.
  8. Best answer selected by Dbringer452.
New Build Systems
