HELP No signal to monitor after new hardware install
Last response: in Systems
Specs:
AMD FX8320
ASRock 970 Extreme 3
Diablotek 500 watt PSU
DVDRW
3x Kingston Red 1600 4GB
1x IPSC 1333 8GB
LCD Fan Controller
Stock AMD FX Fan
120mm Fan
Green Cathod Case Light
WIFI Card
Geforce 210 Video Card
Problem:
So the other day i built this computer and it ran fine, but when i went to install another hard drive, i booted the computer and nothing came up on the monitor. I had no idea what went wrong, so i disconnected it and restarted and had the same issue. I waited a few minutes and gave it a boot up and got video back on the monitor, so left the system as-is.
Then today, i purchased a new green light so i installed it and booted the computer. The PC turned on for a second and turned off on its own. I pushed power again and the PC seemed like it was running fine, but no signal on the monitor.
I feel there are three probable causes of this problem:
1. PSU - not enough juice to support the video card
2. Mobo - not properly able to support the video card
3. Video card - not working half the time
I feel the video card and mobo should be fine because they work prior to a new addition to the PSU load... which leaves me with PSU issue. Any ideas?
Do you think that is the issue?
How do you feel about a thermaltake 600 watt or OCZ 600 stealthxtreme?
Also, i am running 3x 4GB kingston red 1600 sticks and 1x 8gb IPSC 1333 stick, i am told they cannot run dual channel because of the difference in speed, is this true? And how much of a difference does this make? would i be better with 4x 4gb kingston red over my current setup?
Thanks
Feeling that ur PSU is the culprit.
If u have doubt in sticks u can better remove either of and try a system start.
Do it and post lets go to the next step..
Also are u sure that sys doesnot even boot up or if shutdowns when graphic is utilzed(i.e. more load)??
Related ressources
When the computer boots up without additional devices, i have no issues at all outside of the computer behaving a bit slower than expected (explorer.exe constantly stops responding). But like i have said, when i attach new hardware, such as a hard drive, cathod light or whatever the computer starts up but does not have any video output (monitor says no signal). There are no audible beeps from the motherboard and i am certain the 5-pin mobo speaker is connected.
Also, without additional hardware being installed the computer boots fine and shows all the ram sticks working. So i do not think it is the ram... i feel the PSU does not have the juice required for the load despite being 500W (newegg's PSU calculator states i require 400W so im not sure what the issue is). Any suggestions?
