just biult a athlon 1800+ with a sl75drv mainboard and in smartguardian im getting 6 volts on SB5v . could you tell me if this is a problem, should look into changing power suply or weather there is an article showing how much these voltages can change.
hope some one can help.
It's normal that a Voltage differs 0.3 V but 1 V is very dangerous, can frie some components. First try a other monitor app like MBM to see if it gives the same results. If it does it's better to change the powersupply.
My case has so many fans that it hovers above the ground .
this link is the log txt for MBM .
it all looks ok but it does not mention sb5v .
could you tell me what sb5v is for ?
i did wonder if it was to do with the on board sound which i have got turned off eg no current drain as it is disabled.
or is it something to do with the side bus or something.
cheers for your help.
chris
