Monitor says no signal
My desktop will cut on and every once in awhile the monitor will work. But the name of the monitor will show up then it goes to "no signal". I have tried other power supplies and monitor cords. Help!
1 answer Last reply
More about monitor signal
  1. If your system is using an add-on graphics card, try replacing it as it may have failed.
    As they are not a cheap item, see if you can borrow one first (any cheap one will do just for this test), just to confirm that yours is faulty, before buying a replacement.
Prebuilt Power Supplies Desktops Monitors Systems
