So my current system is in desperate need of replacing as it's over 5 years old and as it took me almost 10 minutes of Chrome loading my confirmation page of registering my account it escaped being thrown out the window just barely.
My uses will be mixed use HTPC/web browsing/processing. Mostly HTPC.
I went with a mITX build because it will be beside the TV but often it will be used for both HD out to our TV for movies and web browsing at the same time (wife likes period films, I hate them).
So I don't need a monitor or keyboard or mouse or speakers or DVD writer, those stay.
Here's what I had .. (probably purchasing bit by bit over the next 2-3 weeks from NCIX or wherever else in the lower mainland Vancouver I can find sales for).
:EDIT: Almost forgot would like to stay under $500 and the lower the better.
Case : Cooler Master Elite 120 Advanced mITX Compact Aluminum Case $60.60
PSU: Antec Neo Eco 450C Power Supply ATX 12V $44.99 ($15 off atm)
MOBO: ASUS P8H77-I mITX LGA1155 H77 Motherboard $99.99 ($5 off atm)
CPU: Intel Core i3 3225 Dual Core Hyperthreading Processor LGA1155 $129.99 ($20 off atm)
RAM: G.SKILL F3-12800CL9D-8GBSR2 Sniper SE 8GB 2X4GB DDR3-1600 CL9-9-9-24 1.25V $48.67
SSD : Samsung 840 Series 120GB Solid State Disk Flash Drive $99.99 ($20 off atm)
SSD is solely for OS and main programs, have a couple HDs for storage and will upgrade those later ..
I chose the case so I can fit a few standard HD's as things like the Apex MI-008 only fit 2 and that's with no fan.
I'm pretty sure the PSU will be fine for the build? Using onboard graphics dual LCD/HDTV setup for now.
The RAM is really ugly but it's low voltage and I'd like the parts to last a while. I plan on getting some nice fans with filters as we have 2 cats, pet hair has been an issue.
Not sure if I'm overkilling it on some parts but I absolutely hate waiting for Windows to load and want some damn fine multitasking as I can get heavy on the browser windows and applications sometimes
I also figure if I want to I can replace the CPU, PSU, double the ram and add a good video card if I really want to do some gaming but the heaviest gaming I do is 2d MMORPGs
Looking for some reassurance my PSU will be fine for one, and any opinions on maybe some cheaper alternatives that won't reduce performance much. Maybe I don't need low voltage ram .. but it sounded nice
Thanks!
