Hi guys i have a budget of 500 usd not more, need help on the rest components which are best for the money of course, i currently have ;
Processors : AMD Athlon II X3 440 Rana 3.0GHz Socket AM3 95W
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103843
Motherboard : BIOSTAR TA785G3HD AM3 AMD 785G HDMI Micro ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138181
RAM : Patriot 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220537
(If we could spare some bucks for the replacement of this RAM, it would be perfect)
Keyboard and Mouse : Logitech (Standart)
Here is my Template :
Approximate Purchase Date: Coming 1-2 Week/s
Budget Range: less than 500 USD, i will get from store manually
System Usage from Most to Least Important: Gaming, Movies, Surfing/Chats
Are you buying a monitor: Yes, if enough, (i will add 75 usd)
Do you need to buy OS: No
Preferred Website(s) for Parts: newegg.com (has almost the same prices in my country)
Parts Preferences: Anything
Overclocking: Maybe
SLI or Crossfire: Yes IF Possible i could add 50 usd to replace the motherboard, then trying to get money for the 2nd VGA next month or so.
Thank you guys, please guide me what i should get for the rest of the components.
Overclocking: Maybe
