mikerockett Distinguished Jan 16, 2012 1,347 1 19,465 Jan 11, 2013 #2 Not the greatest amount of detail to work with, if you can get into the BIOS try and disable the chassis intrusion, also check mobo and see if there needs to be/doesnt need to be a jumper over the chassis pins. Upvote 0 Downvote
