First off, this is my first post, so Hi all. I've been struggling along playing games on my terrible machine for a few years now, and its really beginning to show its age, so time for an upgrade! That and my brothers PC decided near 40 degree heat wasn't good for it...and died, thanks to the shonky PSU provided by my mums old PC guy. So here is my build, which I am sourcing parts for from a local parts dealer MSY at brendale
I'm aiming to get this next week, after I get paid, any comments on things I could replace etc. are most welcome.
Budget Range: under $750
System Usage from Most to Least Important: Gaming, Uni, Web Browsing
Are you buying a monitor: No
OS: No
Overclocking: NO
SLI or Crossfire: Yes (in future, and I am aware that dual 7870's would require four pci-e power connections, so I was wondering if I'd be able to buy an adapter later on?)
Additional Comments: I already have my case (Corsair 400r) and my Ram (G.Skill 8Gb 1600Mhz). Im salvaging a DVD/Rw drive from the aforementioned brother's PC.
So without further ado here is my build
Intel BX80637I53470 i5-3470 3.2/3.6GHz LGA1155 IVY Bridge Boxed CPU Cores 4/6MB
AU$185.00
AsRock Z77-Extreme4 Intel Z77 1155/4xDDR3/SATA3/USB3/HDMI/DVI/Glan/RAID ATX Motherboard
AU$135.00
Seagate 3.5" Barracuda 500GB ST500DM002 SATA3 7200RPM 16MB HDD
AU$58.00
Gigabyte GV-R787OC-2GD 2GB 7870 PCI-E VGA Card (SI)
AU$249.00
TP-LINK TL-WN951N PCI 3T3R Upto 300M Wireless-N Network Card
AU$29.00
Corsair GS700 V2 ATX Power Supply Unit
AU$119.00
($25 over, I was worried about running crossfire, so went with the Corsair PSU)
OS: No
Overclocking: NO
AU$185.00
AU$135.00
AU$58.00
AU$249.00
AU$29.00
AU$119.00
