Hi guys,
I just bought a used samsung syncmaster 2433bw and hook it up to my system and it works ok until i go up to higher res the the screen will go off.
If i go say up to 1600 and above which is when it starts to look passable the screen goes off and i cant do anything until i hook it up to my other monitor and lower it.
I have a new system with hd7700 graphics with no problems on my other monitor.
I dont know much about pcs but i think its a settings isssue.
I'm usign vga if that helps and i have the option to use dvi-d but i dont have the cable.
Any advice is welcomed.
Thanks guys
Jon
Thanks guys
Jon
