Sign-in / Sign-up
Solved
Will this Work together? Thoughts/Suggestions? thnx! :3
  • Homebuilt
  • Systems
Last response: in Systems
January 12, 2013 4:47:42 PM
This is the Build so far, minus the Video Card though..
Is this a good build?
Everything fit together?
I will be adding a video card in the future and a sound card.. but i wanted to know if this was all going to work together because i will be purchasing this within the next few days!
(Windows 7) Microsoft Windows 7 Home Premium SP1 64-bit - OEM
http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
(Burner) ASUS 24X DVD Burner
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
(HardDrive) Western Digital WD Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5"
(CPU) Intel Core i5-3470 Ivy Bridge 3.2GHz (3.6GHz Turbo Boost) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637i53470
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
(Mobo) ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
(Ram) G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600
(PSU) CORSAIR Builder Series CX500 500W ATX12V v2.3 80 PLUS BRONZE Certified Active PFC Power Supply
OR
**(PSU)Rosewill HIVE Series HIVE-550 550W Continuous @40°C, 80 PLUS BRONZE Certified, Modular Design
(Tower) Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
Any suggestions or comments would be appreciated! :D
You guys rock!
Thanks so much!
More about : work thoughts suggestions thnx
January 13, 2013 3:56:00 AM
Best answer selected by chaosGeek.
m
l
