I just bought a GTX 650 Ti, been using it for a week or so, at first while I was playing Heroes of Newerth the game would crash to a green or black screen and freezes but there is a sound kinda constant tingling sound. This happens randomly. Next it happened again once while I was playing Assassin's Creed 3. Now I downloaded Dota 2 and first time playing Dota 2, the game crashed and froze to a green screen.
I tried using 1600Mhz speed in my RAM corsair vengeance, thinking stock 1333Mhz was too low or something, but it happened again and now nvidia driver 306.97 stopped working causing vertical vibrating lines appearing in my screen and no input can be made somewhat frozen but it recovered after some seconds.
RAM: corsair vengeance cmz8gx3m2a1600c9
CPU: AMD FX-6100
MOBO: MSI 990fxa-gd80 v2
GPU: Palit GTX 650 Ti non oc
PSU: Aerocool Strike X 600w 80+ True Rated
SSD: Sandisk 120gb Extreme
Now I went and viewed the event log of Microsoft Windows,
I found these,
This is by order of appearance of logs
WLAN Extensibility Module has stopped.
Module Path: C:\Windows\system32\RAIHV.dll
WLAN AutoConfig service has successfully stopped.
Session "Microsoft-Windows-Setup" stopped due to the following error: 0xC000000D
The performance strings in the Performance registry value is corrupted when process Performance extension counter provider. The BaseIndex value from the Performance registry is the first DWORD in the Data section, LastCounter value is the second DWORD in the Data
Unloading the performance counter strings for service WmiApRpl (WmiApRpl) failed. The first DWORD in the Data section contains the error code.
Display driver nvlddmkm stopped responding and has successfully recovered.
Any ideas... Somewhat disappointed with my 650 Ti... I researched and found other problems with 650 Ti
CPU: AMD FX-6100
I found these,
