New Parts To My Computer.
Hi, i am wanting to upgrade parts of my computer and i was wondering if any could tell me if they would work together and play games at good fps (40+)?
My computer specs at the moment;
AMD BULLDOZER SIX CORE FX-6100 (3.30GHz/6MB CACHE/AM3+)
1GB NVIDIA GEFORCE GT 630
ASUS® M5A78L-M/USB3 (M-ATX, DDR3, USB 3.0, 3Gb/s)
4GB KINGSTON HYPER-X GENESIS DUAL-DDR3 1600MHz X.M.P
500GB 3.5" SATA-III 6GB/s HDD 7200RPM 16MB CACHE
600W Quiet 80 PLUS Quad Rail PSU + 120mm Case Fan
SPIRE GEMINI REV.3-THERMAX HDT TWIN FAN CPU COOLER
InWIN MANA-136 BLACK GAMING CASE
WINDOWS 8 PRO
What i wanting to change;
2GB EVGA GTX 660 Ti Superclocked, 28nm, 6008MHz GDDR5, GPU 980MHz, Boost 1059MHz, Cores 1344, DVI, DP, HDMI (NEW ITEM)
650W Corsair Enthusiast Series 650TXV2UK, 85% Eff', 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX v2.31, PSU (NEW ITEM)
WINDOWS 8 PRO
3 answers Last reply
More about parts computer
  1. This topic has been moved from the section Graphics & Displays to section Systems by Mousemonkey
  2. You just need the card change for the 660 ti, your psu is fine, it's a FSP Group oem, 600w is plenty for a 660ti.
    The cpu is not that good(you can overclock it if need it) but it will not bottleneck the gpu, you'll get those fps in most games.
    If you only have 4GB ram get another 4GB, it's cheap.
  3. I agree, just upgrade your GPU and get 8GB RAM. Might want to go with a 7950 instead, though.
    Also, a 120GB or 240GB SSD would be a nice addition if you're looking to spend money.
Homebuilt Computer Systems
