Tom's Hardware > Forum > Windows XP > Device Driver > Printer card problem i xp
Forum Windows XP : Device Driver - Printer card problem i xp
Archived from groups: microsoft.public.windowsxp.device_driver.dev (More info?)
Added a 2 port parallel card ( Skymaster) to a dual boot system running 98se
& XP Pro on two hard drives (C & D)
I installed the drivers in 98 after the system picked up the ports (LPT2 &
LPT3) then installed the printer on LPT2. Printed from the printer ok.
I then installed the drivers in XP after the printer picked up the
ports.Once again the ports (LPT2 & LPT3) appeared in device manager as PCI
EPP/ECP parallel Port (LPT2) & PCI EPP/ECP parallel port (LPT3) under ports.
Also PCI 4018 Multi-I/O Adapter under Multifunction adapter.All look good at
this stage.
However when installing the printer neither LPT2 or LPT3 are available under
ports to use. Even installing using plug & play the system identifies the
printer but the installation fails because the port cannot be found.
Maybe some newer drivers would fix this. Skymaster search was a negative.
Can someone offer some advice here please.
Lindsay
Sponsored Links
There are 569 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
