Are these parts compatible?! AU $1000 GAMING PC
Just wanting to know the compatibility of these parts for my gaming pc build and some suggestions like a different case etc.
Xclio Godspeed Advanced Tower
LiteON SATA DVD-RW 24X Black
Asus VS248H 24" 2ms wide LED w/DSUB DVI-D HDMI
Cooler Master Hyper 212 EVO w Transparent 12cm
Antec VP-550P 550W Strictly PSU
Asrock Z77-EXTREME4 Z77/4 x DDR3/2 x PCI-E3.0/4 x SATA3/6 x USB3.0/HDM
Intel Core i5 3570K LGA1155 CPU 3.4Ghz 6Mb Cache Ivy Bridge
Western Digital 1TB SATA3 HDD 64M Caviar Blue WD10EZEX
MSI GTX660TI,2GB,1019MHz, Display Port, HDMI, DVI,
Corsair 8GB (2x4GB) CML8GX3M2A1600C9 DDR3 1600MHz CL9 Low Profile Vengeance module
Total price: $1009. Thanks in advance!
4 answers Last reply
More about parts compatible 1000 gaming
  1. Yes, you have a good setup.
  2. yes sir. looks golden
    Thanks! do you think i should get a better case or will that do the job?
  4. It's a pretty decent case, it all fits on that case.
    I don't know the prices there, so can't recommend anything, but corsair has a really good budget case like the 200R, antec got the three hundred and the one series, and the nzxt 210 elite for good budget case.
Prebuilt Compatibility Systems
