Sign-in / Sign-up
Solved
System Wont Boot... Error Code "05" on Asrock Extreme 4 Motherboard
  • Homebuilt
  • ASrock
  • Systems
Last response: in Systems
January 13, 2013 6:18:10 AM
Hey guys
I bought parts for a build a couple of months ago.. I tested them all out and i installed windows 8
i recently just got a case for it and a new PSU so i finally went and installed everything in the case.
BUILD:
AMD FX-8350 @ 4Ghz
Samsung Spinpoint 500GB 7200rpm
Asrock 970 Extreme4
G-Skill 8GB (1x8GB) 1600Mhz
EVGA GeForce 8800 GTS
Corsair TX-650w
Sharkoon T28 Blue
Now...
It doesn't boot. The asrock mobo gives me the error code "05" on the little Dr.Debug thing..
It gets stuck on this ( "05" ) no matter how long i leave it..
I Do not get a splash screen or any other visuals coming through..
when booting it gets stuck on this nearly instantly, it appears to be one of the first checks the mobo makes..
The manual says the "05" Dr. Debug error code means that at this time, the motherboard is at the point of:
"OEM initialization before microcode loading"
I have looked everywhere on the internet, while some others do have this problem, they never seem to post their solutions..
The CPU is not and never was overclocked..
I have tried pressing and pressing and holding the clr cmos button on the back of the motherboard.
nothing works...
what could it be?
More about : system wont boot error code asrock extreme motherboard
a c 143 B Homebuilt system
a b δ ASRock
January 13, 2013 6:42:30 AM
flash the BIOS with the latest version from a USB drive
IF YOU CAN
I think you BIOS is older and wont support an 8350 processor
The only other fix is to buy a single core AM3 Duron and start with that installed so you can flash the BIOS
m
l
January 13, 2013 6:46:56 AM
IF YOU CAN
However I was able to boot and install windows 8 with that processor installed and with the bios that came stock on the motherboar beforehand when i plugged everything together to test components?
Thanks for the reply btw :)
m
l
Best solution
a b δ ASRock
January 13, 2013 7:20:28 AM
Sorry i didnt notice you had had Win 8 installed
Id take it out of the case and try bread boarding it again
January 13, 2013 7:29:46 AM
Ok I'll Do that..
Do you think the motherboard might have had something mess up if I get the same error out of the case again?
m
l
January 15, 2013 3:01:10 AM
I solved the problem, the jumper that goes across two of the clear CMOS pins was missing, some found an old one and put it over the "normal" pins as marked by the board and it worked!
I hadn't noticed earlier because i was using the button on the back of the board to clear the CMOS
Thanks outlander for your help, I noticed only when I took everything out of the case lol
m
l
January 15, 2013 3:01:29 AM
Best answer selected by prodigydoo.
m
l
