I'm trying to build my rig around two HD 7970's in SLI. For my CPU I was thinking about buying an i5 -3670k or an i7 - 3820. I have researched these two CPU it seems that they are similar in performance when it comes to gaming. What do you guys recommend? The 3670k is cheaper so I was thinking I should buy that but I heard somewhere that the i7's are better. If I choose the i5 - 3670k I have a choice out of seven motherboards: ASUS® P8Z77-M ASUS® P8Z77-V LX ASUS® P8Z77-V LK ASUS® P8Z77-V ASUS® P8Z77-V PRO/T-BOLT ASUS® SABERTOOTH Z77 ASUS® MAXIMUS V GENE
Which motherboard would you guys recommend if I were to buy the i5? And does the motherboard really effect gaming performance? I f I were to buy the i7, I have a choice of five motherboards: ASUS® P9X79 LE ASUS® P9X79 ASUS® P9X79 PRO ASUS® SABERTOOTH X79 ASUS® RAMPAGE IV EXTREME
And again what whould you guys recommend if I were to buy the i7.
Now for the RAM. I'm thinking about buying 16 gb of RAM. But there are many different versions at different prices. Ideally I want to buy the best version but I don't know what the differences are. Here are the version I came across
16GB SAMSUNG 1333MHz 16GB SAMSUNG DDR3 1333MHz 16GB KINGSTON HYPER-X 1600 16GB HYPERX DDR3 2133MHz 16GB HYPERX BEAST 1866MHz 16GB HYPERX BEAST 2400MHz
Which one is the best one? And is it better to have 2 sticks of 8GB or 4 sticks of 4GB?
Im thinking about getting an 850w power supply, but I don't know what kind of cpu cooler I should get.
If I buy the i5 I have a choice between six different coolers:
Standard Intel Cooler Super Quiet 22dBA Cooler Corsair H40 CPU Cooler Corsair H60 CPU Cooler Corsair H80 CPU Cooler Corsair H100 CPU Cooler
And If I buy the i7 I have a choice between: INTEL SOCKET LG2011 COOLER Super Quiet 22dBA Cooler Corsair H60 CPU Cooler Corsair H80 CPU Cooler Corsair H100 CPU Cooler INTEL LIQUID COOLER
So which one would you recommend for each cpu? I'm thinking of getting the ARCTIC MX-4 thermal paste too.
For my wireless card I would want one that would be able to have a huge range as my room is far away from the router in my house. Should I get a regular card or a dual band card? Would it make a difference in signal strength?
I was thinking of either getting the
HANNS-G HS233H3B 23" 120Hz 3D MONITOR
or
BENQ XL2411T 23.6" 1MS 3D MONITOR
Which monitor do you guys think is better?
Oh and which case do you guys think would be best for these specs and keeping my gpu cool?
I don't care what it looks like on the inside I just want the best parts for the money. I'm looking to keep the PC under £2000 but I will go over the budget if I need to.
Sorry that this was a long post but I would really appreciate some help in answering my questions
or
