I have a problem
So when I open a game ( I have tried most of the newer games, Assassins creed 3, Hitman absolution,Planetside 2 and Battlefield 3) these white lines show up going from the top to the bottom of the screen,(I'm not so sure if it's called flicker or not)but as soon as I close the game they are gone.
I have tried reinstalling drivers,newer,older versions etc, resetted Catalyst settings to default and still nothing.
With a different monitor on the same PC everything is okay and there are no white lines/flicker, and there aren't any white lines with the same monitor on another PC aswell.
Here's my spec:
Gigabyte B75M-D3V
Intel i5-2320
Sapphire HD6790
600W PSU
SyncMaster 2242NW
Please help me, I don't know what else to do.
More about : problem
Related ressources
"With a different monitor on the same PC everything is okay and there are no white lines/flicker, and there aren't any white lines with the same monitor on another PC aswell. "
So the pc works fine with a different monitor, The monitor works fine with a different pc.
Did you use the same cable and type? IE VGA, DVI, HDMI. Or did you use a different cable/type when testing this theory?
*edit* My thought process here is a bad vga, dvi, or hdmi port on either the card or the monitor. OR a bad cable.
Yeah I used the same cable, and it worked perfectly...
It's just weird, there is flicker only when using this monitor on this PC.When using this monitor on a different PC/different monitor on this PC everything is okay.
BUT only After you updated drivers...
i would use the system restore to bring u back to a point Before the time you installed the drivers
