My system the network cable is connected then to it shows unplugged pls help me
my system the net work cable is plugged but it shows unplugged pls help in solving this problem.
1 answer Last reply
More about system network cable connected shows unplugged
  1. Could be a bad cable, or the cable is connected to a bad port on whatever else you've got it plugged into, or it could be a hardware issue with the port itself.
    Try different cables, try plugging the cable into a different router or modem or whatever it is you are connecting it to.
LAN Cable Networking
