Cooler Master HAF X Blue Edition ATX Full Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119239
Dual Monitor Setup: ASUS VS248H-P 24" Black LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153
SLI: GIGABYTE GV-N680Oc-2GD GTX 680 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125422
SeaSonic Platinum-1000 1000W ATX12V / EPS12V 80 PLUS PLATINUM Certified Full Modular Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151105
CORSAIR Dominator Platinum 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233345
ASUS Maximus V EXTREME LGA 1155 Intel Z77 HDMI SATA 6Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131858
Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116502
SAMSUNG 830 Series MZ-7PC512D/AM 2.5" 512GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147136
NO overclocking. This build will be used for game and graphics design using software such as Unity, 3D Studio Max, etc.
CONCERNS:
1) Do I really need 1000W of power for this build or will 850W be plenty?
2) I need a wi-fi card that will be suitable for gaming and I would like for it to be internal instead of one of those USB dongles. Please suggest one for me as I am not knowledgeable in this area.
3) I would also like to be able to use this computer for recording high quality vocals with a mic. Would a sound card be beneficial or will the onboard mobo sound be sufficient? If I get a sound card, will I even have room to install it since I will be running SLI mode?
4) Do I need water cooling or will one of the high end cooler master heat sinks be sufficient? Is aftermarket cooling even necessary at all with this build?
I also just noticed that the EXTREME has more than one x16 slot and the Formula only have one x16 slot. How will this affect my SLI performance?
Thank you for any insights and help!
CONCERNS:
