I am hoping to soon build my first PC. These are my preferences:
Budget Range:500-650 After Rebates
System Usage from Most to Least Important:Gaming, Internet, Music,(storing) Microsoft Office
Parts Not Required: mouse, monitor
Preferred Website(s) for Parts: newegg, amazon, bestbuy, although im open to most others
Country: USA
Parts Preferences: n/a
Overclocking: maybe when i have more experience
SLI or Crossfire: maybe later
Monitor Resolution: 1366 x 768 (720p TV HDMI capable)
Additional Comments: This is my first build, so feel free to give me advice.
CPU: AMD A10-5800K Trinity 3.8GHz (4.2GHz Turbo) Socket FM2 100W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon HD 7660D AD580KWOHJBOX
RAM: PNY XLR8 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model MD8192KD3-1600-X9
DVD/CD/BlURAY player: LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM
GPU: EVGA 01G-P4-3650-KR GeForce GTX 650 Ti 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
Storage: Seagate Momentus XT ST95005620AS 500GB 7200 RPM 32MB Cache 2.5" SATA 3.0Gb/s with NCQ Solid State Hybrid Drive -Bare Drive
Wifi card: Rosewill RNX-N150UBE Wireless Adapter (1T1R) IEEE 802.11b/g, IEEE 802.11n Draft 2.0 USB 2.0 Up to 150Mbps Wireless Data Rates 64/128-bit WEP (Hex & ASCII), WPA/WPA2, WPA(TKIP with IEEE 802.1x)/WPA2(AES with IEEE 802.1x) XP/ Vista/ Win7
Keyboard: i-rocks KR-6401-WH WHITE 103 Normal Keys USB Wired Slim Chocolate Key Style Keyboard
Power Supply: COOLMAX ZX Series ZX-700 700W ATX12V v2.2 / EPS12V v2.91 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
MOBO: ASUS F2A55-M/CSM FM2 AMD A55 (Hudson D2) HDMI USB 3.0 Micro ATX AMD Motherboard with UEFI BIOS
Model
BrandASUSModelF2A55-M/CSM
Supported CPU
CPU Socket TypeFM2CPU TypeAPU (FM2 Socket)
Chipsets
North BridgeAMD A55 (Hudson D2)
Memory
Number of Memory Slots4×240pinMemory StandardDDR3 1866/1600/1333/1066Maximum Memory Supported64GBChannel SupportedDual Channel
Expansion Slots
PCI Express 2.0 x162 (x16/x4)PCI Express x11PCI Slots1
Storage Devices
SATA 3Gb/s6SATA RAID0/1/10/JBOD
Onboard Video
Onboard Video ChipsetNone
Onboard Audio
Audio ChipsetRealtek ALC887Audio Channels8 Channels
Onboard LAN
LAN ChipsetRealtek 8111FMax LAN Speed10/100/1000Mbps
Rear Panel Ports
PS/21 x PS/2 keyboard/mouse portVideo PortsD-Sub + DVIHDMI1 x HDMIUSB 1.1/2.04 x USB 2.0USB 3.02 x USB 3.0S/PDIF Out1 x OpticalAudio Ports6 Ports
Internal I/O Connectors
Onboard USB6 x USB 2.0Other Connectors1 x TPM connector(s)
1 x COM port(s) connector(s)
1 x CPU Fan connector(s) (4 -pin)
1 x Chassis Fan connector(s) (4 -pin)
1 x Power Fan connector(s) (3 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x GPU Boost switch(es)
Physical Spec
Form FactorMicro ATXDimensions9.6" x 9.6"Power Pin24 Pin
Features
FeaturesDIGI+ VRM - Digital Power Design for the APU
GPU BOOST - Go to the Limit with iGPU Level Up!
USB 3.0 Boost - Faster USB 3.0 Transmission with UASP(170%)
Network iControl - Real-time Network Bandwidth Control
MemOK! - Any Memory is A-OK!
Windows 8 Ready - Assured Compatibility
Case: BrandCOOLER MASTERSeriesElite 430 BlackModelRC-430-KWN1
Spec
TypeATX Mid TowerColorBlackCase MaterialSteel / PlasticWith Power SupplyNoPower Supply MountedBottomMotherboard CompatibilityMicro ATX / ATXWith Side Panel WindowYes
Expansion
External 5.25" Drive Bays3External 3.5" Drive Bays2Internal 3.5" Drive Bays5Expansion Slots7
Front Ports
Front Ports2 x USB, 1 x Mic, 1 x Audio
Cooling System
120mm Fans1 x 120mm front blue LED fan
Physical Spec
Dimensions19.30" x 7.50" x 16.70"Weight10.3 lbs.
Features
FeaturesInterior black coating makes stylish inside looks.
Front 120mm fan with brilliant Blue LED provides the best airflow to HDDs.
Rear 120mm fan for high-efficiency ventilation (optional).
Tool-Free mechanical design for quick assembly and maintenance.
Side ventilation holes for better cooling performance.
Large transparent side window included.
Cooling System
-Top: 120 mm fan x 2 (optional)
-Front: 120 mm blue LED fan x 1, 140 mm fan x 1 (optional)
-Rear: 80/90/120 mm fan x 1 (optional)
-Side: 120mm fan x 1 (optional)
-Bottom: 80/90/120 mm fan x 1 (optional)
Country: USA
Model
Supported CPU
Chipsets
Memory
Expansion Slots
Storage Devices
Onboard Video
Onboard Audio
Onboard LAN
Rear Panel Ports
1 x System panel(s)
Physical Spec
Features
Spec
Expansion
Front Ports
Cooling System
Physical Spec
Features
Cooling System
