Closed Solved
GTX 670 SLI Power Consumption
Hey everyone, I have a question about SLI-ing a GTX 670.
But first, the specs:
- Intel Core i7-3770 3.40GHz
- Gigabyte GTX 670 Factory OC WindForce 3X
- 8GB RAM
- Asus P8Z68-V PRO/GEN3 MOBO
- XFX PRO 750W Power Supply
I was thinking of buying myself another GTX 670 for Christmas so I could SLI the two but I was wondering whether I had a large enough Power supply to run the two along with the rest of my parts.
My Motherboard and power supply state they are SLI ready on their boxes, but I just wanted to make sure beforehand.
Any other tips on SLI-ing and/or recommendations for a different card to SLI would be much appreciated as well. I'll also provide any more information on my PC if you desire.
Thanks guys :)
3 answers Last reply Best Answer
More about power consumption
  1. You've got PLENTY of power! SLI 670 draws around 200-250W at most.
    http://www.techpowerup.com/reviews/NVIDIA/GeForce_GTX_670_SLI/23.html
  2. Best answer
    nVidia itself recommend 500W for a single 670.
    http://www.nvidia.in/object/geforce-gtx-670-in.html#pdpContent=2
    For testing conducted for SLI 670, the resulting system consumption for SLI is 433W of which 293W are attributed to the gpu cards.
    http://www.guru3d.com/article/geforce-gtx-670-2-and-3way-sli-review/4
    If you use this psu calculator considering your components, the result is 664W (overclocked processor & used 680x2 to simulate gpu OC:
    http://extreme.outervision.com/PSUEngine
    All points out to 750W being more than enough.
  3. Best answer selected by Nmirko16.
Nvidia Gtx Power Consumption SLI Graphics
