Help deciding whether to use HDMI or DVI (TV as monitor)
Last response: in Systems
- I have a desktop and a ps4, but no TV. How can I play games on my console and use my desktop monitor besides using a DVI-HDMI - Tech Support
- PC works on monitor, but not on TV using a DVI to HDMI convertor. - Tech Support
- DVI to HDMI not looking good using TV as monitor? - Forum
- Should I use an active adapter HDMI/DVI to VGA or buy a new monitor? - Tech Support
- can i run one vga monitor one dvi monitor and a tv hdmi on my ati amd 5450 - Tech Support
- SolvedWhat type of connector to use for a 3d gaming monitor (hdmi, dvi, ect.)? solution
- SolvedPlugging in tv with HDMI to my GTX 590 using a DVI/HDMI converter crashed my computer. solution
- SolvedBios showing on HDMI TV rather than DVI-D monitor solution
- SolvedI get nothing on my monitor when I use a HDMI to DVI adapter solution
- Solvedcan i use hdmi and dvi at the same time for dual monitor 7770 solution
- SolvedTrying to use HDMI instead of DVI, but monitor only says "DVI no input"? solution
- SolvedCan I connect my HP monitor to a Samsung HD TV via DVI-D(monitor) to HDMI(tv)? P Forum
- SolvedMonitor Flickers on HDMI When DVI is in Use solution
- SolvedShould I use HDMI, DVI or DP for my VG248QE Monitor? solution
- Can i use a DVI to HDMI adapter for my 3rd monitor? solution
- Can use the DVI ports to connect GTX 660 to monitor, HDMI port gives no signal connected to HDTV solution
- 3 monitors using DVI, HDMI, and DisplayPort help solution
- SolvedUnable to use hdmi to use my tv as a monitor solution
- SolvedGpu with Dvi, and Hdmi Using two monitors? solution
- More resources
