I purchased the components for a computer and pieced it together about a year ago and am having issues, parts included:
Motherboard: Biostar TH67+B3 Intel H67 LGA1155
Processor: INTEL CORE I5-2320 SANDY BRIDGE 3.0GHZ LGA 1155 6M (I69-2320)
Memory: Corsair 8GB DDR3 PC10666 1333MHz Kit 2x4GB (C13-1007)
Graphics Card: Gigabyte GeForce GTX 560 OC Ed. 1GB GDDR5 PCIe (G452-0566)
Hard Drive: WD Caviar Blue 500GB SATA HD 7200/16MB/SATA-6G (TSD-500AAKX SY)
CD Player: ASUS 24X DVDRW SATA OEM (A455-5022)
Power Supply: Thermaltake TR2 600W Power Supply (T925-3014)
Okay, so the problem is that after piecing it together, everything was great and ran awesome and was everything I wanted...
Then after about a month I started encountering something weird. A temporary locking up and buzzing sound coming out of my speakers during the locking up.
Playing games is when it usually started, or sometimes while watching videos on youtube. If I exit the game/video, it would still continue on for a while some times if I had it only on my desktop screen with every thing else closed.
My first thoughts was that it was probably temperature related, so I would check the temp and it would be fine.
All of this being said, I stopped worrying about it because shortly after, the locking up and buzzing stopped... for a about 9 months until now. It has started again and is very aggravating.
So once again I checked my temps, my GPU is at 34 currently, and my CPU on the "Real Temp GT 3.70" program is showing this:
Temperature (C)
53 50 51 48
Distance to TJ Max (not sure what that means)
46 49 48 50
And then the other temps at the bottom are as follows:
Minimum:
52 48 50 47
Max:
65 64 64 60
I wish I could explain the noise more, but I can't more than it's just a buzzing sound. Not a squealing or whistling or anything... just a buzz.
Also when I say it "locks up" I don't mean I have to shut down, it's just a stutter or something, it unlocks after what I would say about 0.75-1.5 seconds and seems normal for possibly a few seconds at a time, then will do it again.
Sometimes it acts fine... but the times when it doesn't is super inconvenient. If someone could tell me how to trouble shoot this to get it fixed I would greatly appreciate it.
Thank you for your time,
Justin.
Temperature (C)
53 50 51 48
46 49 48 50
Minimum:
52 48 50 47
Max:
65 64 64 60
Justin.
