Yes No
Ads
Tom's Hardware > Forum > Networking > General Discussion > How can I convertmy Motorola Surfboard SB5100 Cable Modem to wireless
Forum Networking : General Discussion How can I convertmy Motorola Surfboard SB5100 Cable Modem to wireless
what do I need to buy ?
Would this work ?
http://www.amazon.co.uk/Wireless-I [...] 471&sr=1-1
also, on the back of the modem is a rectangular, not the typical, usb slot, if that helps.
look
http://modemmodz.co.uk/resources/motorola_sb5100%5B1%5D.gif
okay. so what do I do ?
EDIT : I want to move my computer downstairs.
I cannot move the modem because it is connected to the wall.
I don't want to use an extra long wire either.
What do I need to buy so I can use the wired modem,
as a wireless one on my pc downstairs ?
Message edited by fuggles on 01-06-2012 at 05:59:03 PM
Reply to fuggles
That's only for a computer. The USB slot is a regular USB, it's just the other side of the cable used for devices not PC connections.
You need a Wireless Router. Take a look at this http://www.amazon.co.uk/TP-Link-TL [...] omputers_2
------------------------------ Recommended Video Cards: http://www.tomshardware.com/review [...] ,3085.html
Reply to hang-the-9
- 0 +
Okay, that makes sense and thanks.
Aren't there any cheaper wireless routers ?
Would this work ?
http://www.ebay.co.uk/itm/Belkin-W [...] 3f117b0c65
Okay, once the router is set up.
I plug a USB dongle into my pc, and that's it ?
Reply to fuggles
There are cheaper ones, but you want one that will work across floors. The one I linked has good reviews for it's signal strength. One that's worse may still work, but maybe slower, have drop outs, etc...
Not that it's guaranteed that the one I linked will work for you, it really depends on the distance between the PC and the Router and what's in between them.
Yes, setup Router, note the wifi settings and password you select, install the USB wifi in the computer, it will come up with a list of wireless networks it sees. Pick yours, enter password, done.
Message edited by hang-the-9 on 01-06-2012 at 11:52:23 PM
Reply to hang-the-9
You can always use a cheap wired router and a power line adapter also. I like power line much better than wireless it's just as fast and you don't have to worry about signal loss.
Reply to jchambers2586
- 0 +
hang-the-9 is right, a wireless N router and copatible adaptor on your pc will give you better range than a wireless G router. Without any garantees it's probably the best solution.
Reply to ngrego
There are 1495 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
