Custom build help
Hey I was thinking about buying a pre made pc from a site then swapping out some of the components.
Was thinking of getting http://www.ebay.co.uk/itm/Vantage-3-3Ghz-Intel-Core-I5-2500K-Windows-7-Gaming-PC-500gb-Hdd-16gb-DDR3-HD-/140774723468?pt=UK_Computing_DesktopPCs&hash=item20c6d3cf8c
Then swapping in,
motherboard: Gigabyte GA-B75M-D3H
GPU: Sapphire 11200-16-20G HD7850 GDDR5 Graphics Card (1GB)
I was wondering if this would work? Any help would be amazing as I don't really know anything about building a PC.
I'm looking to spend sort of upto £700ish
3 answers Last reply
More about custom build help
  1. if you dont want to build your own then i would suggest going with cyberpower becasue these pre-built pc's on ebay generally skimp on things that wont be very attractive for a novice such as the psu this is evident as the brand or wattage is not even listed
    i would go with this at least you get a years warranty.#
    http://www.cyberpowersystem.co.uk/saving/show.aspx?id=544811
    i know its over budget but they are putting it together for you and giving you a warranty and shipping it.
  2. thanks, this looks like a pretty handy website
  3. i would still learn how to build a computer it's a very useful tool for troubleshooting and is always nice to know.
Homebuilt Systems
