Approximate Purchase Date: In two weeks or so from now.
Budget Range: 2000-2400
System Usage from Most to Least Important: Gaming, Multitasking(surf the net, watch youtube, netflix, listen to music, fraps, ect...)
Are you buying a monitor: No, maybe later will buy a 2nd monitor for dual monitor setting.
Do you need to buy OS: Yes, also would like Windows 7 Ultimate Edition.
Preferred Website(s) for Parts: First timer here so I have no clue my last gaming rig which I still use is an Alienware.
Parts Preferences: Intel.
Overclocking: Not sure if it's needed or not it sounds risky and if parts are pretty good do you really need it?
SLI or Crossfire: Not sure either do I need 2 GPU if I buy a pretty good one? I had GTX 295 3 years ago and it is a dual GPU card but found out my main game FFXIV was using only 1 GPU and I had all kind of issues.
Your Monitor Resolution: 1920 X 1080 but might buy 2nd monitor.
Additional Comments: Main reason I want this PC is gaming but I also don't want to see slowdowns or errors.
Currently I have an Alienware Aurora 3 years old and specs are:
CPU i7 920 @ 2.67Ghz Oced by Alienware @3.2Ghz ( last few days I had many issues with Guild Wars 2 lag and installed CPU-Z and I see the frenquency move up and down from 1.6Ghz-3.2Ghz)
GPU had GTX295 and had many issues with it will never consider a dual GPU card now have 6950 and has been much better then GTX295 but still few times got some minor display errors.
Ram 9gig
windows 7 home premium.
Ram 9gig
