Archived from groups: rec.photo.digital.slr-systems (More info?)
Hi... I am looking at a new Nikon D50 or D70s and I am curious: what
will happen if I try to use an older SB24 Flash with the camera? Will
it work at all, or is it a must to upgrade that to a new flash like the
SB600 or 800?
Works with D70 according to the review above, so should be same for D50 and
D70s.
"John M" <jsak@centurytel.net> wrote in message
newsdOdnZIL-f7LuHHfRVn-jQ@centurytel.net...
> Hi... I am looking at a new Nikon D50 or D70s and I am curious: what will
> happen if I try to use an older SB24 Flash with the camera? Will it work
> at all, or is it a must to upgrade that to a new flash like the SB600 or
> 800?
> Thanks for your help, John.
> SB600 or 800?
You just won't have TTL auto flash metering. Other than that it will work.
"John M" <jsak@centurytel.net> skrev i meddelandet
> 800?
You can get it flashing without a camera!
You can also use it as a slave flash with an flash trigger!
