Solved
Will this PSU supply enough power for this computer build?
A friend sent me this list for a computer he is building.
The mobo manual recommends a PSU of 500 watts or greater.
We just want to find out if the power supply is enough to power the mobo and the other listed components below or if a higher wattage psu is needed.
CPU: Intel i5-3570K
MOBO:Gigabyte GA-Z77X-UD3H
RAM: Patriot Viper 3 (2X4GB PC3-12800 DDR3-1600 9-9-9-27 1.5V) Dual Channel Memory Kit
GPU: XFX Radeon HD 7850 Core Edition 860MHZ 2GB 4.8GHZ GDDR5 2xDVI HDMI 2XDP PCI-E
PSU:XFX 550W PRO550W Core Edition Single Rail ATX 12V 44A 24PIN ATX Power Supply 80PLUS Bronze Certified
HSF:Cooler Master Hyper 212 Plus Direct Touch 4 Heatpipe Heatsink AM2 AM3 LGA1366 LGA1155 LGA1156 120mm
CASE:Fractal Design Define R4 ATX Mid Tower Window Case Black (2X5.25) (1X3.5) (8X3.5 INT) 2X2.5 SSD
OS:Windows 7 Professional 64-BIT
R/W CD/DVD Drive: Generic
Harddrive: 7200 RPM 1TB Western Digital Caviar Black
SSD: Cruical M4
2 answers Last reply Best Answer
More about will supply power computer build
  1. Best answer
    Yes, that's enough power, but you won't have enough power to add another video card. If you decide to do that in the future, you'll need a bigger PSU.
  2. Best answer selected by chrisbek.
New Build Computer Systems
