Help With My Old Laptop Video Card Problem
i have my old laptop Dell Inspiron 6400 Core 2 duo @ 2ghz and a Ati Mobility Radeon x1400
My problem is When i play games like pcsx2 or any games and watching Bluray movie
the memory clock is going down and down until it reach only 135mhz something so when i play games but the gpu clock is stable only the memory clock is going down and down so i get hang when playing games and watching movie so what i do is when the memory clock is going down until it reach to 135mhz something i use powerstrip to set the default clock again but sometimes it will hang and crush the laptop it will produce some lines and hang so i need to restart my laptop what do you think my problem and how can i fix it thanks :) )))
Graphics card Expert
chrodechild14 said:
i have no battery it set to balanced ???
Is the video card have problem ?
Let me clarify myself.
Your laptop has no battery connected to it, so you are using the charger connected directly to the mains to keep it on? And while doing that, your battery mode is in balanced?
Related ressources
chrodechild14 said:
yes the power plan set to balanced..
i can't get any software to monitor this gpu temp i used gpu-z,speedfan,evga precision, hw monitor.. ahmm i laptop keyboard is hot i think ... does that mean overheating can cause my gpu memory down ??
Possible, though I don't know how to fix it sorry
