Motherboard Help!!!
Last response: in Systems
Hi. Are you sure your ASUS desktop has an ASRock motherboard? Anyway if your motherboard has a PCI Express X16 slot which a H61 motherboard does, then it will support the HD 7770. The one thing that might not support your graphics card is the power supply unit. Do you know its brand and model or the +12V rating?
