New PC -- Blade & Soul!~!
Last response: in Systems
Approximate Purchase Date: Within 6 months.
Budget Range: N/A
System Usage from Most to Least Important: Gaming, Movies, Streaming, Work
Are you buying a monitor: No
Do you need to buy OS: Yes
Preferred Website(s) for Parts: Amazon, Newegg, Tigerdirect, Microcenter...anything
Overclocking: Maybe
SLI or Crossfire: No
Your Monitor Resolution: 1920X1080
Additional Comments: Prefer a quiet, high performance PC with durable components and cost efficiency is a plus.
And Most Importantly, Why Are You Upgrading: It's been 5 years.
http://pcpartpicker.com/p/xZ5d
Please let me know what you think.
Budget Range: N/A
Overclocking: Maybe
More about : blade soul
Related ressources
- [ PC Gaming] Blade and soul - Forum
- Will Deepcool Ice Blade Pro fit in my PC ? - Forum
- Razer Blade help plz! - Forum
- Twin frozr III 6950 Fan blade broke. - Forum
- Broken Fan Blade EVGA GTX 560ti - Forum
PCPartPicker part list: http://pcpartpicker.com/p/xGwa
Price breakdown by merchant: http://pcpartpicker.com/p/xGwa/by_merchant/
Benchmarks: http://pcpartpicker.com/p/xGwa/benchmarks/
CPU: AMD FX-8350 4.0GHz 8-Core Processor ($189.99 @ NCIX US)
CPU Cooler: Thermaltake CLP0596 88.8 CFM CPU Cooler ($46.99 @ Newegg)
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard ($124.62 @ NCIX US)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory ($74.98 @ NCIX US)
Storage: Seagate Barracuda 1.5TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($98.97 @ Amazon)
Video Card: Gigabyte Radeon HD 7950 3GB Video Card ($289.99 @ NCIX US)
Case: NZXT Phantom (White) ATX Full Tower Case ($119.99 @ Amazon)
Power Supply: XFX ProSeries 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($122.75 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($24.98 @ Newegg)
Operating System: Microsoft Windows 8 (OEM) (64-bit) ($87.99 @ NCIX US)
Total: $1251.24
(Generated by PCPartPicker 2013-01-17 01:40 EST-0500)
Base Total: $1266.25
Mail-in Rebates: -$20.00
Shipping: $4.99
Total: $1251.24
thats the amd build
heres my intel build:
PCPartPicker part list: http://pcpartpicker.com/p/y28I
Price breakdown by merchant: http://pcpartpicker.com/p/y28I/by_merchant/
Benchmarks: http://pcpartpicker.com/p/y28I/benchmarks/
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($87.55 @ Newegg)
Total: $1214.17
(Generated by PCPartPicker 2013-01-17 01:42 EST-0500)
Base Total: $1261.62
Combo Discounts: -$13.00
Shipping: $12.55
Total: $1241.17
quite good for the price
Total: $1251.24
Shipping: $4.99
Total: $1251.24
thats the amd build
Total: $1214.17
Shipping: $12.55
Total: $1241.17
**PRINT THIS**
Z77 Sabertooth tips:
- BIOS. Flash to the latest. If you have issues (like me) flash to the second latest (before 1708 I believe)
- ASSIST FANS: Install AI SUITE II and adjust the profile so that these fans turn OFF COMPLETELY until 50degC (they whine and aren't needed so turn OFF)
- SOFTWARE: do NOT install the entire suite of software. It caused my PC to crash and would NOT reboot. I had to insert my Windows 8 disc and RESTORE to the last restore point before I installed the software.
- SETUP: make sure you select XMP so that your MEMORY timings and frequency are selected properly. Your BIOS can slightly overclock the CPU with the "overclock" feature but you may need to play around to make sure your memory doesn't default to lower settings.
* All things considered I'm happy with the motherboard but you need to know the above.
SSD:
A 64GB is simply NOT BIG ENOUGH. You need a 120GB SSD and I suggest you have a hard drive as well and use it to:
a) install STEAM and GAMES
b) Downloads
c) Media
Your SSD will fill up over time and I can guarantee a 64GB SSD is simply not big enough.
SSD tips:
- keep 20% free space
- flash the firmware (preferably before using)
Windows 7 or 8?
I recommend Windows 8 64-bit OEM rather than Windows 7, and buy Start8 from Stardock. I basically use it like Windows 7 and never use the new Start Screen. However, there are IMPROVEMENTS in Windows 8:
- boot time
- stability
- security
- Windows Explorer
- other minor changes
*Also, once the new Start Screen catches on you can use it if you want.
CPU: i5-3570K (I agree totally)
SUMMARY:
- tips for Sabertooth Z77 board
- i5-3570K
- 120GB SSD
- secondary Hard Drive
SSD:
b) Downloads
c) Media
SSD tips:
Windows 7 or 8?
- boot time
- stability
- security
- Windows Explorer
SUMMARY:
- i5-3570K
- 120GB SSD
shur alright,
heres a revised pick of ur parts.
PCPartPicker part list: http://pcpartpicker.com/p/y7x3
Price breakdown by merchant: http://pcpartpicker.com/p/y7x3/by_merchant/
Benchmarks: http://pcpartpicker.com/p/y7x3/benchmarks/
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Motherboard: Asus P8Z68-V PRO/GEN3 ATX LGA1155 Motherboard ($144.99 @ Newegg)
Memory: Corsair Dominator Platinum 8GB (2 x 4GB) DDR3-1866 Memory ($89.98 @ Amazon)
Storage: Samsung 840 Series 120GB 2.5" Solid State Disk ($99.99 @ Amazon)
Video Card: Gigabyte GeForce GTX 670 2GB Video Card ($379.99 @ Newegg)
Case: Fractal Design Define R4 (Titanium Grey) ATX Mid Tower Case ($95.68 @ NCIX US)
Power Supply: Corsair Enthusiast 850W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($99.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($89.98 @ Outlet PC)
Total: $1215.58
(Generated by PCPartPicker 2013-01-17 17:13 EST-0500)
Total: $1215.58
one thats just marketing talk, and theres certain types of damage that it doesnt cover, doesnt really give u better heat dissipation thats just hyped, and doesnt enhance ur graphics, only graphics u get enhanced is from a videocard.
this has a 3year versus 5 year warranty, but if it hasnt broke within 3years i doubt it will change, also technology changes so fast ull prob upgrade within 3-4years anyways.
Prices don't drop that much for the last generation hardware when the new stuff comes out (unless you're buying used). Look at the difference between an i5-2500k vs. the 3570k. It's the same for video cards. If you're going to wait 6 months anyway, you might as well get the new tech.
And +1 to not overpaying for a gimmicky mobo.
Related ressources:
- ForumMount and Blade - Best game of 2008 you probably never heard of.
- ForumNew game: Mount & Blade
- ForumWill my GPU be ok without 1 fan blade ? (AMD RADEON 6770)
- ForumGetting PC 2 - 8500 OCZ BLADE DDR2 DIMM recognized as 1066
- ForumBlade /Turbine Master, Silent Eagle, Gentle Typhoon... Which?
- ForumRazer Blade ?
- ForumIBM HS20 Blade
- Forum'Razer Blade ' laptop using the GeForce 555M... underpowered?
- ForumGTX 570 Fan Blade broke off
- ForumIs this gaming PC okay?
- ForumBuilding New Computers
- ForumNew system in old prebuilt case
- ForumNew build need suggestions
- ForumBuy New PC or OS upgrade?
- Forum[New Build] Really expensive
- More resources
