Hello,
mine is an hp dv6 2005ax laptop.its wont boot.
previously i had to turn in on first for about 1 min and then turn off by pressing power button and then turn on again to boot, now it just wont boot. the battery is dead.
Hello,
If you know the battery is dead why don't you send it for repairs?
Have you tried checking if there is any loose RAM in the laptop? If that doesn't work, try shifting the RAM. This may not be the problem but it has happened to me, except I do it on a desktop
okk. did that as well, no use. check this video.
http://www.youtube.com/watch?v=MXeaCQcVLVY&ytsession=Mr7KC2PgVCV36gEQkXXLVgZNOduYCGsnE1lnZwBxySLi6nSIsqtM6fl4GBxIw_AcwDqGV4tTUL1O_mQdB8wutfV5AgsAczcAwEnJF8P5wN5CXBjMO0yb3lksPPLVyVGEeOcNg-9bMbMg3JCxVIF-aCkBFMKY2kyEkXNOKt_khuDLRMmt3CAss29SggM7GAierUX9fAz23nJI9CWWjzxb-eHeu7Npcr3O9v7Re2BuFss
Hmmm. I guess the GPU has stopped working or some short circuit might have blown it
