I've been given a Geforce 9600 GT 512MB Pci-E graphic card (Club 3D brand); it looks good but I don't know if it's working or not.
I installed it into a PC with Win XP, but its power supply doesn't have the 6-pin power connector for Pci-Express cards (required by the card).
When the PC booted there was no video signal going to monitor (monitor remained in stand-by), on either DVI ports.
Now my question is: the card not outputting any signal, shows that:
A) The card is dead; or
B) Card is Ok, but without the 6-pin power input it cannot even begin to work?
(the card is rated at 95W max power draw)
PS: I know I could use a 2 Molex to 6-Pin adapter, but I'd like to know if B) above can be true, before purchasing it.
PS2: Power supply is 600W, so it would be fine powering the card.
